How to create a type of 'alarm event' based on acquired sensor data and system time?
Accepted by topic author dweedle
Hi dweedle,
You can connect output of > function (Where you are checking if voltage is>1) to "OR" function and to other terminal of or function you will connect output of "In Range" function. Output of "In Range" function to "Select function"..I guess this will solve your problem
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 11 of 11
(529 Views)
