01-29-2008 08:15 AM
I'm using LV just to create that file. This file is used by another application which doesn't accept [ ] and =
What would you advise me?
01-29-2008 08:33 AM
01-29-2008 09:38 AM
01-29-2008 10:12 AM
01-29-2008 10:21 AM
01-30-2008 05:14 AM
01-30-2008 06:23 AM
01-30-2008 06:52 AM - edited 01-30-2008 06:54 AM
Hi GerdW
i think to use the Label can be an advantage while devoloping, because if the label change you don´t have to search for the constant.
Hi Kabanga
i attached an example for you, to show how you can clean up your blockdiagram. Therefore you have to change the red frame with the green frame. It should do the same.
Mike
01-30-2008 06:59 AM
Hi Mike
thanks for your help.
I'm using LV 8.2.
Could you plese save it under LV 8.2 and send it again?
Best regards
Kabanga
01-30-2008 07:01 AM
Hi Kabanga,
i´m sorry. Here is the 8.2 version.
Mike
