How to create a string array?
Thanks!
(4,819 Views)
Same way you'd create any other type of array...  Drop an array on the front panel, and then drop a string control/indicator into it.
(4,811 Views)
Use Create Array, Build Array, an array constant on the block diagram or front panel, for loop, etc. The best way depends on what the heck you're actually trying to accomplish. I suggest you provide some more details and maybe take a class or on-line tutorial. Info on leaning LabVIEW can be found here.
(4,810 Views)
