How to create a front panel like the getting started window of LabVIEW
Hi
I want create a front panel that is similar to the Geeting Started window of LabVIEW . Please send me your suggestions and supporting documents or VIs to do it.
Thanks and Regards
Anish G
Certified LabVIEW Architect
Message 1 of 11
(3,890 Views)
Hi AnishG,
attached you will find my solution.
Hope it helps.
Mike
Message 2 of 11
(3,871 Views)
Here are a few tips from the person who wrote the GSW:
  1. An Object-Oriented Getting Started Window
  2. Code Reuse through Classes
  3. Designing VIs Before You Write Them
  4. Customizing the Getting Started Window
I believe you should also find the code if you search the LAVA forums.
___________________
Try to take over the world!
Message 3 of 11
(3,845 Views)
Hi Mike,
Even i'm about to post a simila query.....
I'm not sure whether i'm posting at the right place.
I've a developed a VI for my validation team, which they will use for one of their projects as VOice recognition Testing tool.
But currently the VI's i developed doesnt have a proper show up.
I mean the marketing is not proper (cosmetics need to be applied for demos and all)
Could you please let me know is there any way in Lab view which would help me to showcast my project in an efficient way.
Because whenever i give a Demo to other teams they seems disappointed about the look and feel of my project.
But internally the way it works is good.
Your advice would be a gr8 help.
Cheers,
Suneel.V
Message 4 of 11
(3,835 Views)
Also search examples for "Navigation.lvproj"
Message 5 of 11
(3,802 Views)
Hi Pnt,
I couldnt find this "navigation.lvproj"
Could you please explain me whats there in that.
Because the moment i open my VI it shows only a table control window.
So i wanna do something which give life to my project.
A perfect marketing appearance should be there...
Waiting for your response.
Cheers,
Suneel
Message 6 of 11
(3,766 Views)
It is in the examples of Labview 8.5.
If you have a previous version, it may not be there....
Message 7 of 11
(3,763 Views)
You should find it here (adapt the path to your LabVIEW version and installation directory) :
C:\Program Files\National Instruments\LabVIEW 8.5\examples\lvoop\navigation\Navigation.lvproj
Message 8 of 11
(3,762 Views)
Oh but unfortunately i'm using 8.2
thank you...
Message 9 of 11
(3,760 Views)
Can anybody save it for 8.2 and share it for me here....
Thnaks in advance.
Message 10 of 11
(3,741 Views)
