How to create a Detect Device Feature in my program
When a device is connected to my program, I wish to see some indications, like the name and properties of the device, to appear on the left side of the front panel. I have attached my program. Pls kindly advise what are the tools or functions i should use and how should I connect them to my program. Thanks a million!!
Cheers
MC.2
(3,043 Views)
Could not open your vi.
But I suggest you go through the example codes in  these two links: one is to get device info using DAQmx property nodes and other to get info for VISA Devices
See if you can incorporate it in your code
Message Edited by devchander on 10-30-2006 03:31 AM
(3,039 Views)
(3,031 Views)
(3,031 Views)
Its ok do not repost your VI,  I could not open because I might be having a lower version of LabVIEW.
Do take a look at the links I have sent and let us know if it helps you
Message Edited by devchander on 10-30-2006 03:47 AM
(3,030 Views)
