How to create a DLL for LabVIEW in MatLab
I want to use MatLab-Code from an M-file in LabView without MatLab. So i decide to use external code in a DLL. Can anybody give me some hints - how to do? (How to create, how to use?)
Used System Windows 98, LabVIEW 6.1, MatLab 6.1 R12.1
(4,783 Views)
I use Matlab-Code in Labview and it's don't need create a dll. The LV was a tool, matlab script, you can write your code Matlab here. see the examples of LV.I think the lV 6.1 have.
Dll it's very complicated 😄
(4,783 Views)
I would like to use LabVIEW !without MatLab. If i use these solution i need MatLab too.
(4,783 Views)
I've investigated and i think that it's not possible to run a compiled m-file without the matlab runtime server
Look at http://www.mathworks.com
(4,784 Views)
You can use only the Matlab runtime.
Install the runtime and the libraries that you are using.
(4,208 Views)
