How to create a 60 Hz timed loop?
Hi all,
I want to have a 60 Hz timed while loop.
By default this block has 1 KHz clock source.
How can I change its timing source to 60 Hz?
Thanks in advance
(4,747 Views)
@Baran_ wrote:
Hi all,
Thanks in advance
Perhaps the better question to ask is: Why?
Are you trying to generate a 60Hz signal?
Bill
CLD
(Mid-Level minion.)
(4,737 Views)
I want to display an image with submultiple of 60 Hz flickering rate, and different frequency and phase of displaying.
So I thought about doing that with a precise timed loop.
(4,712 Views)
In Windows you will never get a "precise timed loop".
That having been said, take a look at this:  https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P82BSAS&l=en-US
(4,706 Views)
If you don't care about jitter (which you'll have on Windows anyway) you could set the dt alternately to [16,17,17] in each iteration.
(4,690 Views)
