How to create 2d slider?
How to can i create 2d slider, something like square with mouse controlled point in it in the upper left corner on picture, so I don't need to use 2 seperate sliders for x and y?
(4,223 Views)
Try using the mouse over event.  It give you coord on the control you are using it on.
(4,213 Views)
Create a point style cursor (no lines) and use cursor move events to get x and y.
(4,200 Views)
Accepted by topic author gmilek
Here's what I had in mind (LV 8.0). Modify as needed.
(4,194 Views)
This is another nice example, but a little more complicated.
The advantage , that it can be implement on every Control/Indicator kind.
(3,831 Views)
