How to create 2D array
Hi
I am pretty new to labview. I need to make 250x250 array filled with value 300, so I can substract this array from an array derived from an image (for background substraction). How can I do this?
thanks.
(5,488 Views)
nm, i got it.
(5,479 Views)
Well, you don't tell us how you are doing it, so here's the correct way.
You pose the question wrong, because you don't need to create a 2D array at all, you can just subtract a scalar from the 2D array and LabVIEW does the rest. Is that what you got?
Message Edited by altenbach on 08-18-2008 04:45 PM
(5,474 Views)
reallly?
when i subtract it, it just doesnt let me put in constant. it asks me to put a 2d array. the thing is that I have a imaq vision (yes that $3200) and it had subtract operator... but I'd love to know how you did this though.
(5,471 Views)
Sorry, I don't have the vision stuff, but if you use the plain subtract primitive from the numeric palette, subtracting a scalar from a 2D array should work without problem.
Maybe you are trying to use a more complicated tool designed to subtract two images from each other?
How doesn't it "let you"? How does it "ask"? Do you simply get a broken wire?
Can you explain?
Message Edited by altenbach on 08-18-2008 05:25 PM
(5,467 Views)
If you wire the array to the subtract first and then right click to create a constant to the other input it will default to an array.  For the constant input, create the constant first and then wire it.
Jim
LV 2020
(5,458 Views)
