How to create 1 file per second
I am new at LabVIEW and I found a VI example similar to my needs. But I need it to create 1 file per second with a date/time stamp going automatically to the name of the files. Is there a way to do it?
Luis
(3,447 Views)
Accepted by topic author LuisAlonso
Hi Luis,
surely there's a way!
See this:
(FormatDateTimeString is found on the Time functions palette...)
Use this filename with a BuildPath function to create a path for your next file...
(3,432 Views)
Thanks GerdW!
I am still having a problem to make it save automatically without I having to press the OK button, is there a simply way to do it? I updated the attached VI with the GerdW tips
Luis
(3,406 Views)
Hi Luis,
please resave your VI for older LV versions...
(3,401 Views)
Do you still have the file dialog.vi in ?
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,397 Views)
I think it will work for older versions now.
I dont have the dialog.vi
Luis
(3,371 Views)
Hi Luis,
so now you create one file (and its name) once before the loop. But your goal is to create a new file each second...
I would try to open a new file in the loop when you want to change filenames with a regular interval...
(3,369 Views)
