How to creat variable
I am very beginner to labview and i want to creat variable which get value 1 when input get 1 and not change when input 0 .
(2,391 Views)
Hi Chathuac,
As a "very beginner" you should start with all those Training resources offered at the top of the LabVIEW board…
All you need is a while loop (as your input may vary over time), a shift register (your "variable", as LabVIEW uses wires and shift registers instead of "variables") and a case structure (input may be 1 or 0)…
What have you tried and where are you stuck?
(2,381 Views)
Accepted by topic author Chathuac98
In LabVIEW, the wire is the variable., you can branch the wire to an indicator if you want to also display it to the user. 😄
If you simply don't want to update an indicator, place it in a case structure and execute an empty case if zero happens, else update the indicator. If you also need the value elsewhere, keep it in a shift register or feedback node across iterations.
In addition, you really need to define the problem better.
  • Where does the "value" come from?
  • Where does the "input" come from?
  • Is "input" the same as "value" or different?
  • What causes "it" to change? How often?
  • What are the starting values? For example if the input is always zero, there is no obvious value to retain.
  • Are these integers or floating point values?
  • What should happen is the input is neither 0 or 1 (e.g. -1000, 34567, Pi, NaN, etc.)
  • etc.
(2,379 Views)
So, it'll be Off until activated and then always True. A shift register and an Or can fix that.
Qestit Systems
Certified-LabVIEW-Developer
(2,323 Views)
