How to convert this matlab code to labview?
 result = find( ([(arrayofval >= minvalue); 0] & [0; (arrayofval < minvalue)]) |...
([(arrayofval <= minvalue); 0] & [0; (arrayofval > minvalue)]) );
thanks in advance.
Message 1 of 17
(4,563 Views)
anyone can help me on this? thanks...
Message 2 of 17
(4,552 Views)
Be patient. Your post is only an hour old and most of the members here are volunteers.
Message 3 of 17
(4,545 Views)
Hi simply_ynan,
  Are you sure that is exact expression you want to find out..Which version of labview are you using?
Thanks and regards,
srikrishna
Srikrishna
Message 4 of 17
(4,539 Views)
I'm using labVIEW 2010. Yes, this is the code currently I have in Matlab and would like to convert it to LabVIEW.
Message 5 of 17
(4,534 Views)
Hi simply_ynan,
  But i think utlimately the value will be an empty array?Correct me if i am wrong..
Thanks and regards,
srikrishnaNF
Srikrishna
Message 6 of 17
(4,524 Views)
Hi srikrishnaNF,
That's also my case here. But when using this code in Matlab, I didn't get an empty array. Thanks for helping.
Message 7 of 17
(4,519 Views)
Simply_ynan,
What is your result in Matlab with this code? I am with srikrishnaNF on this one and I would think you would get an empty array. Can you let us know what you are getting in Matlab and then we can better understand what results you should be looking for and thus how to implement your Matlab code in LabVIEW?
David A.
Message 8 of 17
(4,486 Views)
What is a typical set of parameter values you used in matlab?
Message 9 of 17
(4,470 Views)
arrayofval is equals to values in arrayofval.csv(attached file) and minval is equal to -7.9925.
Then running that code in Matlab will give us the values in result.csv(also in attached file).
Thanks.
Message 10 of 17
(4,458 Views)
