How to convert string to 0 and 1
Hi
How can I convert this string "11110000" to this number (16bit or 8 bit) 11110000. Could you please help me with this?
Thanks?
(2,906 Views)
Scan from String using %b as format specifier should work.
(2,895 Views)
well I use %8b and %b but it converts the following string "11110110" to 246!
(2,888 Views)
Change your display format on your indicator to binary. Decimal 246 is b11110110.
EDIT: I read too fast and posted the wrong binary representation originally, sorry.
(2,883 Views)
Decimal 246 = 11110110 binary.  You just need to change the display format of your indicator to binary.  Representation should probably be U8.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(2,881 Views)
