How to convert llb from LabVIEW version 8 to 7.1
Can someone tell how to convert the llb from LabVIEW version 8 to version 7.1?
I hope to sent the program to the others, but the other side are using LabVIEW version 7.1 but not version 8.0.
I know I can save to VI file as previous version, but it contains severals of VI in the library, it is quite time consuming.
Can everyone sugguest any method or solution to solve my problem.
Thanks.
(3,686 Views)
If you have a top level VI that uses all of the other VIs in the llb, then just do a Save As of the top level. This is one of the reason that instrument drivers have a 'Tree' VI in the llb.
(3,678 Views)
Thank you very much.
It show warning in transferring process.
Will these warning means it cannot run in previous version?
(3,655 Views)
Hi anson,
it will run also in LV7.1 - but you should check those warnings (probably things not/differently supported by LV7.1...) anyway!
(3,653 Views)
