How to convert boolean array to an numeric count array
I am having a array of Boolean consider the following example
My goal is to count the first LOW or HIGH values of array continuously and it should output the counted value . Then the next value is HIGH or LOW, it should count and display it to next.
For easy understand I can say diagrammatically which is given below
HIGH  value count should be in positive and LOW value count should be in negative. The output is array. I think this is quite simple but I don't know the logic.
Message 1 of 25
(5,765 Views)
That was a fun little exercise.  What I did was use a Feedback Node to look for a transition.  If they were the same, I incremented a count.  If they were different, I took the count and negated if the previous value was a false and then added it to an array.  For the setup, I also added the inverse of the last value to the array to make sure there was a final transition to get the end of the array.
Message 2 of 25
(5,760 Views)
It was fun.
Here is what I came up with.  The XOR with 1 cycle input delay finds the edges.
The conditional tunnel builds the array on the edges.
Since there is no last edge, I concantenated the counter after the loop finishes.
Message 3 of 25
(5,742 Views)
I thought I could do better but I don't think it is.  But there is room for improvement.Boolean to Numbers.png
Message 4 of 25
(5,733 Views)
I'm a little surprised how tedious this task it but here is my attempt using array search.  It will be interesting to see a side by side comparison of the different methods.
aputman
Message 5 of 25
(5,718 Views)
Oops....i just realized my code is wrong if the last boolean is a F.  The count is not negated.
aputman
Message 6 of 25
(5,709 Views)
It is tedious.  I had that same bug.
I think it is fixed now, although it is starting to feel a bit rube-ish.
This has to be a more elegant solution to the adding last counter problem... (creating the last edge)
Message 7 of 25
(5,699 Views)
Okay got it fixed.
I was stuck on using the negate function foolishly.
Message 8 of 25
(5,676 Views)
I hear you.  Here is my updated version without negate.
aputman
Message 9 of 25
(5,666 Views)
Hope you don't mind but I found orders of magnitude improvement by removing the for loop, and replacing the while loop with a for loop.  In my test running the code 10000000 times took about 8459ms to execute, but after these two changes took 2ms.  I tried a few other ideas but couldn't come close to this.  Oh automatic error handling and debugging was turned off for the test.
Message 10 of 25
(5,651 Views)
