How to convert a string to visa resource name
I have a string , like "visa://192.168.123.212/RIO0::INSTR", how can I convert it to a Labview visa resource name? The resource name is going to be used for "Open VI reference" control.
Also, a related question is , is there a special vi control for ip address input?  How do I check whether the input ip address is in valid format or not?
Message 1 of 17
(12,495 Views)
Just wire it up. A string will coerce to a resource name.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 17
(12,488 Views)
Mike...
I don't think it does. At least not for me. I am having the same problem, I am trying to wire a string to the VISA resource name and doesn't work.
Message 3 of 17
(6,197 Views)
@dadest100 wrote:
Mike...
It works for everybody else.  But as it stands, no one can help you because "doesn't work" is too vague, and you didn't provide a VI that you're having trouble with.
Message 4 of 17
(6,193 Views)
Hi Leiyuan,
It works for us to wire a string to a VISA reference:
No, there is no special (frontpanel) control. You can check for 4 integer numeric values in the range of 0…255, separated by dots…
(Search the forum, this question has come up before.)
Message 5 of 17
(6,175 Views)
@paul_cardinale wrote:
@dadest100 wrote:
Mike...
Hi Mike, yeah sorry apologies my input string wasn't formatted correctly that's why it didn't work.
Cheers
Message 6 of 17
(6,151 Views)
The proper way is to use Type Cast
=== Engineer Ambiguously ===
Message 7 of 17
(6,135 Views)
Only if you have an aversion to coercion.  😉
Bill
CLD
(Mid-Level minion.)
Message 8 of 17
(6,132 Views)
IMHO: Coercion dots are a sign of failure 😛
Message 9 of 17
(6,127 Views)
That's a little extreme.  Coercion Dots are red flags to issues, not a sign of complete failure.
Message 10 of 17
(6,121 Views)
