How to convert a string to binary?
Hello Ex-jobb,
you should use the hex conversion routines in the string palette. This will convert your hex string to a number. Then do the conversion to boolean array, pick the bits you need and append them to a new array. This array can be back-converted to a number. It's fairly easy...
Message 11 of 12
(747 Views)
There is no need to use a boolean array for this problem. Using the bit level operators, you can do this pretty simply. See the attached example (LV6.1 or better to view).
Message 12 of 12
(730 Views)
