How to convert Waveform Attribute to 1D String Array
I'd like to convert Waveform attributes (as in picture) to 1D String Array. Can someone provide solution on this...?
SD_LV
Message Edited by SB_LV on 12-22-2009 10:58 AM
(4,216 Views)
Accepted by topic author Blessing_Star
Hi SB_LV
Check below image:
Might be solve the problem.
Viru
(4,187 Views)
Your question asks for a 1D arry of Waveform attributes, but your picture shows that you want a 1D array of attributes from a 1D array of Waveforms (where each element  contains all of the attributes of the corresponding Waveform).  I'm going to assume the latter.
I'm typically interested in Channel Names and Units from these attributes.  So to add to Viru's post, this may also be useful for you:
Message Edited by Nickerbocker on 12-22-2009 10:38 AM
(4,171 Views)
Thanks Viru & Nickerbocker. Thanks for the quick response.
Message Edited by SB_LV on 12-22-2009 11:45 AM
(4,165 Views)
