12-10-2004 10:48 AM
12-10-2004 02:39 PM
12-10-2004 03:07 PM
12-10-2004 04:03 PM
@Dennis Knutson wrote:
Are you refering to the front panel logging option? The actual binary format is going to depend on what controls and indicators you have on the front panel and their data types. There is an example of using the file i/o functions to read one of these files in chapter 14 of the user manual. The problem you'll have if you write a program to read a log file is that every time you add or delete a control/indicator, you'll have to rewrite your program and then you'll be unable to read older log files. You'd be better off writing your own log routines. Then you would control the binary format. There are shipping examples that you can look at for fbinary file storage.
