How to convert LLB from 5.1 to 8.6
The preferred way to convert old files seems to be through a post. I was not able to find a tool which was occasionaly mentioned in the forums.
 Thank you so much.
Chuck
(3,720 Views)
That library seems to be incomplete - there are global variables missing. There are also links to VIs in other libraries. For whatever it's worth, attached is the library in 8.2, which you should be able to open in 8.6.
(3,715 Views)
Thanks. Yes, it is just one of several libraries in the application. I need to see how a particular feature was implemented, I don't need it to work 🙂
Chuck
(3,713 Views)
hello all. I have a huge problem with the conversion of *. LLB version 5.1 to version 2012. I also have the 8.5 version that I can use as a first step for the conversion. But also through the LLB Manager can not convert them. Can anyone help me? I put in the attached file that I need to convert. Thank you very much.
(3,285 Views)
(3,283 Views)
Post in the Version Conversion board and I will be more than happy to help.
(3,278 Views)
OK! i'm sorry!
(3,273 Views)
