How to convert 8 bits hex string into 1 byte number
Hi
I have small problem. The problem is I want to convert 8 bits Hex string into 1 byte hex number.
For example:0A00 0B00 0000 0200 into 1 byte number.
 I have tried many time and i always get result as 0.
Thank you in advance
BR kalu
(2,796 Views)
I think you definitions are messed up.  A bit is a boolean value (0 or 1).  8 bits = 1 byte.  You actually have 8 bytes in your number.
Just be to completely clear for what you want, please make a quick VI that shows what you are trying to do.  Be sure to set example data at defaults.
(2,791 Views)
