How to control font size in express vi windows popups?
My Windows XP user interface uses many popup messages generated by the "Display Msg" express vi.  Is there a way to customize the appearance of those popups, e.g. larger font?
Jeff
Climbing the Labview learning curve!
Sanarus Medical
Pleasanton, CA
(2,817 Views)
Hay,
I'm afraid the only way to do that would be to edit the font programatically when the dialog box is displayed.  That or you would need to edit the actual express vi code.  Or of course, you could make your own dialog (it is kind of fun to do, unless you are on a time budget).  Sorry!
7J1L1M
(2,808 Views)
If I'm correct you can change any express VI into normal (static) VI's.
Open the front panel of the pop-up VI and select the text, now change the font from system into something different.
Ton
My LabVIEW Ideas
(2,794 Views)
