How to control a second monitor with labview???
Ok, thanks for all.
Message 11 of 16
(2,610 Views)
Don't be scared.  This is just a learning process here, just keep in mind all help here are free.
If I am correct, you just want to send to image to your hardware (may treat like second monitor).
My sugggestion:
First, connect SLM to PC, setup up PC with dual view monitor. Configure SLM as second monitor if the video driver is correct.
Second, change the resolution, make sure the resolution of the second monitor match with SLM
In your LV program, create a vi which send image to SLM on second monitor, Then should be OK.
Any questions will be welcomed here.
TonP shows you how to dynamically controll the monitor, it may out of your expectation. But I learn a lot from TonP's post. Thanks TonP.
Message 12 of 16
(2,593 Views)
I.m glad ti see so much interes and I want to thank  both.
I already did what you told,
michenglaoxu, my problem apear when I must to do something in labview, because I'm new. Anyway, now I'm trying to do what TonP shown me and if I'll have some problem I'll ask you.
Thanks again.
Message 13 of 16
(2,588 Views)
Hi  Raul,
Rereading my post started a bit harsh.
But as michen  pointed out by reading you can learn still (the trick I showed I learned after 2 years of fulltime LV-use).
I want to keep the discussion public because someone else might (most likely will) have a better solution.
For future reference it might be best to include parts of code you want help with.
I know this question isn't quite suitable for that so I didn't ask Smiley Happy
Ton
My LabVIEW Ideas
Message 14 of 16
(2,576 Views)
Hi TonP,
first I want to thank you for all the advices. If we are speaking about LabVIEW there was two, and both was very useful.
Now I want to go forword with my application. So, now I'm able to send an image to an second monitor, in my conditions. Next step is that this image are generated by an matlab software. Do you know how I can to acces an matlab program from LabVIEW?
Thanks, Raul.
Message 15 of 16
(2,537 Views)
Well, there are some strategies to call Matlab program in LV, you can search the posts in this forum.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/12922 and
http://forums.ni.com/ni/board/message?board.id=170&message.id=108713&query.id=9173#M108713
blah,Blah,......
instead of accessing Matlab program in LV or accessing LV application in Matlab, my suggestion is just bring the image generated by Matlab into LabVIEW not Matlab code.  As for how and when image being generated, you can control it in matlab.
Normally, I reallly don't think it a good idea to embedded on language source code into the other language source code unless you have to. Especially, for a large project, this may cause more issues.
Message 16 of 16
(2,518 Views)
