How to control a Toshiba T6963C LCD Display using Labview
Hello there,
Could anyone help me or advice me how to control a Toshiba LCD using LABVIEW via PXI-6229? or any alternative NI HW is required?
Walter.
(3,735 Views)
Hi Walter,
have you read the datasheet for the display? It pretty much explains how to communicate to this device...
(3,727 Views)
Hi GerdW,
Yes, I have read it but I dont really understand how to use PXI 6229 to control/sending characters to the Display. Would you mind to help me?
Thanks!
Walter.
(3,721 Views)
Hi Walter,
your PXI6229 provides 48 digital I/O lines.
The datasheet of the LCD is talking about 8 datalines (D0-D7) and 8 address lines (a0-a7). Maybe you need some more additional lines (like RW) for the communication protocol - here it is up to you to read the manual...
You have to configure the used DIO lines as output and send the correct data according to the described protocol. I would use the 8 lines for data and address each as block of lines for easier writing of byte values.
(3,717 Views)
Hi GredW
Thanks for your advice. Meantime, would you mind to explain in more details as below,
"I would use the 8 lines for data and address each as block of lines for easier writing of byte values."
8 lines means???
each as block of lines means??
Many Thanks!
Walter.
(3,709 Views)
Could anyone can help me how to control T6963C LCD Display?As below,
I have setup up all the connection to the T6963C via PXI 6229 i.e. WR, RD,CE, C/D, RESET and FS1. For data line is D0..D7.
I am sending High to WR,RD,CE,C/D,RESET and FS1 and D7..D0 is 100111 i.e Text on, Graphic ON accroding to the DATASHEET but I dont see any things happen on the LCD display. Please help!
Walter.
(3,667 Views)
