How to control Telnet timeout
In my application I'm using Telnet protocol.
I noticed that when I'm trying to read data using the Telnet read.vi the timeout is not the timeout I specify, rather it looks like it's exactly twice the number of ms I specify. The Read operation I perform respond differently so I must understand how to control the timeout.
In the attached example vi I open a telnet session, reads the response and then closes the session.
Although a 5000ms timeout is specified the actual timeout of the read operation is about 10000 ms (between the 2 breakpoints).
Is this some kind of bug or am I missing something ?
Can anyone help ?
(3,231 Views)
Hi Mentos,
You are correct in saying it is a bug. This is a known issue in LabVIEW (~twice the timeout you set). R&D is aware of it, CAR 51523.
Message Edited by JeffL on 2009-08-27 01:29 PM
Jeff | LabVIEW Software Engineer
(3,210 Views)
OK,
As long as I know I'm not doing anything wrong on my side I can take care of it.
Thank you.
(3,187 Views)
