How to control NI PXI 2503 using labview?
I am vishal.
i have a task in which i have to monitor temperature of different components.
labview platform is used for making software that takes output from thermistor through NI PXI 2503  multiplexer and converts it to digital
 using ni pxi5152 digitizer.now i have to control both of this instruments and take values from digitizer.
but the problem is that i don't know which VIs will be used to control these instruments, because i am doing this first time.
I just know that NIDAQmax VIs can be used, but don't know how to use them.
Please some one give me a little bit start for making this program.
thank you.
(3,000 Views)
Accepted by topic author vishhh
You may find this helpful: Combined Measurements with NI PXI Switch Modules and High Speed Digitizers. Basically NI-Switch is used to control the multiplexer.
(2,994 Views)
thank you, i shall check it.
and contact for any other need.
thanks a lot
(2,966 Views)
