How to control DTR (FP-2000) with compatibility serial vi (not VISA)?
I need to directly control DTR on the serial port of an FP-2000, which doesn't support VISA. Any suggestions? Thanks.
Matt
(2,683 Views)
Matt,
The VI located at vi.lib\platform\_sersup.llb\serial line ctrl.vi allows you to set DTR line. The acyual path in vi.lib depends on the version so if it is not there make a search in vi.lib directory for a file named _sersup.llb.
LabVIEW, C'est LabVIEW
(2,683 Views)
