How to continuously receive x/y coordinates when selected from an image
Hi, I am looking on how to receive the x/y coordinates when a user selects a point on an image.  The code that I've come up with so far works, but not to my requirements.  The code attached below, pops up a window and the user selects the point, then the coordinates are displayed.  This causes two problems, it is not continuous.  What I mean by that, is that I wish to allow the user to keep clicking on random points of the image and have the coordinates displayed.  Also, I do not wish to have a popup window, the user would select the points right on top of the image on the front panel.  Please let me know if you can think of a way to do this.
The other image displayed below is for reference.  I wish to have parts of the image arranged in some sort of pattern for the user to select.
Thank you!
(2,971 Views)
Hi Robot,
Check this. Is this you want?
Silver_Shaper | CLD
(2,951 Views)
@sac. wrote:
Hi Robot,
Hi SaC,
Thank you! It is very very close... all I need would be for the user's mouse click to activate the x/y points to be used. I revised your code to show that I'll be using the x/y points to run different cases. Right now, I just used the x coordinate for an example. However, I would only like these cases to be run if the mouse has been clicked. I tried using the Activate Mouse and Aquire Input Data VIs, but they only return the x/y points from the whole monitor, not just over the image. Any ideas?
(2,937 Views)
@R0B0T wrote:
@sac. wrote:
Hi Robot,
Hi SaC,
Actually, I found a way to have LV do what I want. I experimented around with the Activate Mouse and Aquire Input Data VIs.  Check it out and let me know if you think this is a good way of doing it.
(2,928 Views)
Hey robot,
This might be a good idea of doing.Try to avoid red dots in divide function replacing with quotient and remainder function. Post your final code so that can help you much better.
Silver_Shaper | CLD
(2,917 Views)
