How to continously generate a voltage signal with dynamic amplitude.
Hello all,
I am looking for ideas and pointers (help in other words). I would like to generate a voltage signal (sine for example) on a AO of my NI cRIO-9263 (DAQmx). The signal should be:
  • continuous (without jumps ie. smooth)
  • dynamically able to be change the amplitude, frequency and sampling rate.
  • interuptable so that the AO can be turned off.
I have tried to use the DAQ Assistant but once it runs in continous mode, I have the impression that the waveform should not be changed. Is there maybe a way where I send repeatedly N samples of the waveform to the AO and gain more control over the signal that way. But if I do that how can I ensure that the signal is continous?
Further more this output has to be generated in an event application ie. in the background.
Your ideas and input is appreciated. Thanks, Bernie
(2,921 Views)
See if this example VI helps
Ches this one too
[broken links removed; examples no longer available]
(2,917 Views)
Thanks that will do the trick. I appreciate your help.
(2,896 Views)
Glad to have been of assistance Smiley Happy
All the best
(2,887 Views)
