How to connect 2-wire strain gage to NI 9237 by quarter bridge
I have a Strain Gage: KYOWA KFG-20-120-C1-11 (2 wire) http://www.kyowa-ei.co.jp/english/products/gages/pdf/kfg-01.pdf, NI 9237 on a Compact DAQ (cDAQ 9174) and RJ-50 (10-pin modular plug to pigtail wires).
Strain Gage features:
Gage Factor: 2.08 +/- 1.0%
Gage Resistance: 120.2 +/- 0.2 Ohms
I'd like to connect them to measure the strain with quarter bridge configuration but I have some doubts about which line goes to which terminal.
Thanks.
(5,483 Views)
Accepted by topic author Burzredion
You can find the manual for the NI 9237 module here
It's a good idea to buy an NI 9944 or NI 9945 Quarter Bridge Completion Accessory if you're planning on using this module with a quarter bridge configuration, but  you can look at the following diagrams to see what kind of internal connections are implemented: Connecting Strain Gauges and Shunt Resistors to the NI 9237
PS Posting in the DAQ or signal conditioning forums instead of Labview may get you better/faster answers.
Cheers
Message Edited by mishkin on 03-11-2010 02:40 PM
Misha
(5,475 Views)
