How to configure the loop rates ?
I am trying to execute two time loop one at a rate of 1000 Hz and other at rate of 200 Hz. The problem I am facing right now is when I am executing the code they are not operating at the assigned frequency. Also I wanted to stop the loop execution when the 1st loop (200) Hz stops, the 2nd should also stop.
(1,157 Views)
Accepted by topic author rishab_kr
Hi rishab,
Again you failed in attaching all subVIs
The loops can only iterate as fast as the code inside can be executed: which loop rates do you achieve in comparison to the "assigned frequency"? (THINK DATAFLOW!)
Then you need to change the stop condition of the 2nd loop…
(Maybe another program structure might be useful: why do you need to output the same values 5 times per calculation of those values?)
General recommendation:
Cleanup the block diagram to use straight wires.
Never hide labels in the block diagram.
(1,134 Views)
Related to attaching VIs : I am not sure weather it will work or not in your system as it contain lots of file like FPGA and Sub VI.
I have shared the final one with one screenshot the upper time loop I executing at 1000 Hz and the lower one is at 200 Hz. Also I am not able to figure out how to stop the upper loop when the bottom one stops executing.
Also I am not able to understand your question about the " why do you need to output the same values 5 times per calculation of those values" ?
I wanted to understand the possible reasons of such behavior, like the loop rates  ?
I am really learning a lot out of your comments. Your comments are really crisp and to the point . Waiting for your another valuable guidance.
Thanks in advanced.
(1,112 Views)
Hi rishab,
You did not answer my question: which loop rates do you achieve?
You already know how to stop the loops in the first two sequence frames using the STOP button using a boolean function.
You know how to stop the TimedLoops based on the STOP/Stop buttons.
But now you don't know how to stop those loops based on conditions calculated from several boolean values???
One loop is calculating a matrix at (desired) 5ms intervals.
The other loop is using that matrix at (desired) 1ms intervals.
What happens inside the subVI so you need to use the same calculation result 5 times per calculation?
(1,102 Views)
