How to configure the call library function using a dll for HID communication
under http://helmpcb.com/software/usb-hid-template-for-visual-basic-2005 you will find a template for "Visual Basic" to set up a hid communication with a usb device.
I want to use the included mcHID.dll to communicate with a hid device by labview. Now I have some problems to configure the call library function node for the dll to set up the hid communication. The API of the dll is describe in the file mcHIDInterface.dll.
Maybe someone could set up the first functions in an example. I am using LabView 2012.
Thanks a lot an best regards,
Michael
(7,764 Views)
The solution is very simple. I found a complete LabVIEW Library which includes the mcHID.dll. I hope it is okay to attached the library.
Now it is totaly easy to start a USB HID communication with labview. I tried it and it works fine.
Michael
(7,745 Views)
sorry to have awaken this old beast, however, I have downloaded this library and I have this for the HID device:
First let me make sure that I understand the process correctly and the first thing I need to get is a handle?
The VI's provided in this library have inputs as unsigned integers, however the VID and PID are Hexadecimal values - this is confusion number 1
Confusion number two: I tried converting the controls to HEX and trying to aquire a handle, I also tried converting the hex vals to decimal nad still get 0 (nothing?) for a handle
For VID I have used 5A7 (or 1447), for PID I have used 40FE (16638)
any help is appreciated.
(7,171 Views)
Michael,  i didnt get it to work
(6,412 Views)
Hi Michael,
Can you please advise what should be the value for pHostWin. I have assigned the correct PID and VID. For pHostWin i leave it at 0. However i get nothing at the read buffer array.
Thank you.
Crystal
(5,394 Views)
Hi
I am trying to communicate with the HID device that has a proprietary driver, could you send me an example of a simple communication VI for testing? I created this topic describing my problem.
https://forums.ni.com/t5/LabVIEW/I-cannot-communicate-between-Labview-2019-and-HID-Compliant/m-p/408...
(4,876 Views)
