08-22-2008 06:09 PM
I'm trying to read in a text file containing two columns of strings into a two-dimensional array. I'm trying to use the VI called "Spreadsheet String to Array".
Based on probes, I'm apparently reading the text file correctly, but I'm unable to generate the array. I'm most confused by what to wire to the input pin called
"array type (2D dbl)". The "Help" page says that this input is the "data type input" for the array. The default is 2D, double-precision, floating-point numbers.
My array is a 2D array of *strings*. I cannot figure out what I'm supposed to connect to this input to tell the VI that my array is to consist of 2D strings, and
not 2D-dbl.
Suggestions? I've tried to attach a simple version of this VI to illustrate the problem.
08-22-2008 06:36 PM
08-22-2008 07:00 PM
Even simpler, right-click on the type input and select "create constant". You'll get the default input for it.
Now right-click on the array element (not the array container) of the diagram constant (currently DBL) and select "replace...navigate to the string palette...select string constant". Voila, now you have a 2D array of strings. If you want a 1D array of strings, simply resize the array index.
