How to configure a call library function node for a function whose argument is a data type defined in windows API
I want to configure call library function node for a function which has the argument of type HANDLE which is a data type defined in the windows API.
The function prototype is  void CanGetReceiveEvent(int handle, HANDLE *hevent);
HANDLE is declared as
typedef PVOID HANDLE;
and PVOID is pointer to any type and is declared as
typedef void *PVOID;
can the call library function node be configured for such data types.
(3,195 Views)
hi Vandana,
Can U tell us what Dll are U trying to call in Ur application ?
I'm not quite sure, but I think sometimes U can define the datatype as "Adapt to Type" in case of ambiguity, like the situation wherein U need to pass a numeric array which can be Signed or Unsigned or Double.
Also see the Data format ring in teh CLF configure window, U can see the thing "Poinnters to Handles".
Try like this & update here, experts will surely help U out better than me.
Partha.
- Partha ( CLD until Oct 2027 🙂 )
(3,192 Views)
Hi Partha,
I am using the DLL for CAN interface(7841.dll).
If I use Adapt to Type for the argument, I think I should give a control to this argument. So, control of which data type should be given ot this.
Please clarify
(3,184 Views)
