11-03-2010 09:01 AM
Hi Guys,
I have a small question regarding datetime.
I have the following data in an array in timestamp format .
01:00:00.000
19-05-2009
01:00:00.000
22-05-2009
01:00:00.000
23-05-2009
What I want to do is to check which date is greater then the other. Simply my question is how to do comparison between dates , specially when they are in time stamp format
Secondly I would like to ask if I have a timestamp which has the following values
01:00:00.000
22-05-2009
How do i convert it into seconds ?
Thankyou
Solved! Go to Solution.
11-03-2010 09:42 AM - edited 11-03-2010 09:42 AM
@OmarTariq wrote:
Hi Guys,
Just use a comparison function directly. The functions are polymorphic. If you don't understand what polymorphism is, then please review the LabVIEW Help and the LabVIEW tutorials, as they cover this behavior.
01:00:00.000
22-05-2009
Just use the Numeric Conversion functions. This will give you the number of seconds number of seconds that have elapsed since 12:00 a.m., Friday, January 1, 1904, Universal Time.
11-03-2010 09:45 AM
You can build an array of time stamps and use the array min/max to compare sets of timestamps.
Use the to double conversion to get seconds since...
11-03-2010 09:52 AM
Oops, missed that we're dealing with more than 2. Yeah, if you've got more than 2 then an array is the way to go.
11-03-2010 09:56 AM
Great , thats what i wanted.
Would like to thank both of you 😃
Rgs
Omar
