How to communicate or send signals from labview going to 8051 microcontroller?
jmvrd wrote:
Btw, how can i change the picture(array) set at the strumming VI? im planning to change and modify the said pictures (the one with arrows, and arrows lighted up and down). thanks again.
All you need to do is to create the picture in your favorite program, copy it, then go to the picture ring, select the item you want to replace, right-click on the item and select "Import from clipboard".  See Adding Picture Items to Ring Controls in the LabVIEW Help.
Message 21 of 24
(1,173 Views)
Just would like to thank you for all the help! i was able to communicate with my board and edit my program thanks to all your help.
Just want to ask some help regarding my C program. Can anyone make this program a lot simpler and will have a shorter lines but the content wont be affected? Right now i have a problem with my microcontroller. It cannot burn the said program because it has many lines and codes in it, so i would want to simplify this program so that the microcontroller would be able to recognize it. Please see attach.
Also, would like to ask, how could you put a delay on DTR program of labview? i would like to add some delay to it so that it wont shift so easily. Please see attach as well. Thanks
Message 22 of 24
(1,144 Views)
another thing, how do u create a pop up menu? when you click on a certain button, another view or option would appear like series of texts or instructions. thanks again.
Message 23 of 24
(1,140 Views)
Post #22 moved to here.
Post #23 moved to here.
Message 24 of 24
(1,120 Views)
