How to combine Digital Graphs
how to combine or merge the 1D array of digital waveform with a simple digital waveform. As givien in the attached VI, I want to display the datalines graph & control lines graph in a single digital waveform graph.
Thanks in advance
(3,125 Views)
Accepted by topic author RAVIDVK
Hi gurum,
Well, you can use 'Build Array' to merge the 2 1D arrays and connect the output to the Digital Waveform Graph as shown below:
Hope it helps
Warmest regards,
Lennard.C
Learning new things everyday...
(3,057 Views)
