How to combine 3-D Array pages?
I have a 3-D array of data and I’d like to combine all the pages into one table. Is there a way to do it?
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
Message 1 of 11
(5,538 Views)
Try Reshape Array to take it from a 3-D to a 2-D.
Message 2 of 11
(5,528 Views)
Hello Ravens, I've tried it and actually went to 1-D array and the result was mixed... I'm looking to view it in one page with the same format.
Thanks!
______________
KowdTek
LabVIEW 2009
Message 3 of 11
(5,519 Views)
Did you expand the Reshape Array so you could wire 2 dimensions? By default the Reshape Array has only one dimension.
I don't understand what you mean by "view it one page with the same format". Same format as what? And what do you mean by one page? Can you provide a manual example of what you are trying to accomplish?
Message 4 of 11
(5,515 Views)
I want something like this.
Thanks!
______________
KowdTek
LabVIEW 2009
Message 5 of 11
(5,505 Views)
Accepted by topic author KowdTek
Here is one possibility. Since your 3D array has a variable number of empty rows on each page, a simple reshape alone will not be sufficient, you also need to eliminate empty rows.
I don't know what kind of row order you want, but my solution gives a different order than your desired output. Still, this should get you started. You might need to sort the rows differently.
There could be bugs, so modify as needed.
Message 6 of 11
(5,501 Views)
Thanks altenbach!!!
That's exactly what I want...Smiley Tongue
______________
KowdTek
LabVIEW 2009
Message 7 of 11
(5,482 Views)
I want something like that.
Message 8 of 11
(5,271 Views)
Your math calcualting the indices is wrong.
Here's a corrected version, see if it makes sense.
Also:
  • Don't hammer data back and forth using value properties! That's the most inefficient way, because it is synchronous.
  • Use a delay in the loop. The inner code only needs to be recalculated when the inputs change, and not millions of times per second.
  • If in doubt about the indices, use a debug output to veryfy what actually happens.
Message 9 of 11
(5,248 Views)
Thank you so much!
Can you help me to see one more program?
See the program.
If any changes in slider, I want to store 2 values: String value & Slider value inside 2-D Array.
Can event structure handle for 3-D Array?
Message 10 of 11
(5,219 Views)
