How to collect a sine wave using PCIe-6363?
The board is an amplifier. It ouputs sine wave, I already measure the output with oscilloscope, it's correct.
Message 11 of 17
(185 Views)
@cainiao wrote:
Thank you sir, I connected BNC ground to the power supply, the wave appears. But here's another question: It seems that the wave is a bit distorted. How can I solve it?
Your sampling rate may be low, trying increasing it to the max supported
Santhosh
Soliton Technologies
Message 12 of 17
(182 Views)
Hi cainiao,
Did you notice my previous message?
What is your sample rate and what is the frequency of that sine wave?
Message 13 of 17
(175 Views)
Hi, GerdW
The frequency of sine wave is 1kHz. Sample rate 9kHz. I think it obeys Nyquist theorem.
Cainiao
Message 14 of 17
(158 Views)
@cainiao wrote:
Hi, GerdW
Cainiao
Please keep in mind that Nyquist criteria preserve only the frequency and not the quality (i.e., shape). A 1kHz sine wave sampled at 2kHz will show up as a triangle wave after sampling.
You need to sample at 10x or more the frequency to acquire or generate a reasonable quality sine wave.
Santhosh
Message 15 of 17
(150 Views)
Hi cainiao,
Your first message told very different numbers!
Now you get just 9 samples per sine wave: what do you expect?
Message 16 of 17
(146 Views)
Thanks for your reply. I will try later
Message 17 of 17
(140 Views)
