09-26-2005 06:59 AM
09-27-2005 02:07 PM
Hello James and Roger,
What do you mean by "encoder state change?" If you just mean a change in position, then you should use either the A or B lines of your encoder to clock your analog input (AI). The Counter Output Event signal only pulses (or toggles) when the counter reaches its terminal count.
If you just want to take an AI sample with every click of the encoder, you will need to physically route the A or B encoder line to a PFI line, and use that PFI line as the source for your AI Sample Clock.
I hope this helps. Please let me know if you have any further questions.
Sean C.
09-27-2005 02:21 PM
09-28-2005 12:11 PM
09-28-2005 12:16 PM
Thanks Sean, that answers our question. We'll go with the external circuitry idea.
--James & Roger
