How to click the login button that coded as javascript not form submit button in labview
I want to login webpage through labview. I can open the webpage, input the password, but I can find the name id for the 'login' button. Base on code, the 'login' button is coded as javascript not form submit.  Any idea how I can click that 'login' button.  The portion of webpage is like:
<br />
<form name="logform" action="login" method="post" onsubmit="ProcessForm()">
<div class="container">
<br />
<input type="password" placeholder="Enter Password" name="password" value="" required>
<br />
<button>Login</button>
<br />
The ProcessForm() is the function
Thanks for your help
(6,055 Views)
You can try using the javascript click() method as outlined in the following link:
HTML DOM click() method - https://www.w3schools.com/jsref/met_html_click.asp
The following link might also be useful to learn more:
Simple JavaScript and HTML with LabVIEW Web Services - http://forums.ni.com/t5/LabVIEW-Web-Development/Getting-Started-Series-Simple-JavaScript-and-HTML-wi...
Please let me know if you have any questions.
(6,000 Views)
Thanks Shreyas.
But in example, the clicked button all has "id"  and you can get that element name.  In my case, I can not find the element for that login button.
(5,984 Views)
Is it possible for you to add a custom "id" element to the code?
(5,970 Views)
