08-21-2013 10:49 AM
How to choose the trigger signal in NI-SCOPE Express:
When I run NI-SCOPE Express VI, I choose Trigger type (Digital), Source (PFI 1),
Slope (Positive), and Delay (0). The trigger signal is come from PXI-5412
(Function Generator).
When I use the other function generator, how to choose the Trigger type?
There are 6 choices (immediate, edge,¦digital..). I tried them. Only the type of
(immediate)works. But it is not sync with the signal. The other 5 choices do not
work. (The other function generator usually sends out a trigger signal for an
oscilloscope). Which kind of trigger type can be used?
08-22-2013 09:05 AM
Are you physically routing the PFI line from the FGEN? You could actually route the signal on the backplane using the PXI_Trigger lines. You need to export the trigger from the FGEN and set up the trigger for the scope on the PXI_Trigger line.
