How to choose FPGA Bit-file depending on hardware
Hi James,
Ahh that's a nice way that you are doing it. I did try exactly the same as you have, but without the knowledge of interface cast I couldn't get it to work as the two bit-files, whilst the same functional code produced different references and the terminals wouldn't match.
In the end I have done it like this. I am currently just putting the relevant bitfiles in the C drive on the RT target and then putting the path in the BitfileLocation.txt file. Its quite a nice method in that I can know update the FPGA code without having to produce a new version of the RT software.
 There is going to be a little bit of work to upload the bitfiles to the RT target and set up the .txt file but I'll try and finesse that in the future.
Thanks for everyone help and suggestions.
Regards
Mark
Message 11 of 11
(333 Views)
