02-22-2006 01:40 PM
02-22-2006 01:51 PM
The dialog is probably appearing because you have Auto Error Handling turned on. This feature is turned on by default in LabVIEW 7.0. You should go to VI Properties (Ctrl-I) > Execution and deselect "Enable automatic error handling". Also you should go to Tools > Options > New and Changed in LabVIEW 7.x and deselect "Enable automatic error handling in new VIs". If you never want to see one of those dialogs again, you can also deselect "Enaeble automatic error handling dialogs"...I wouldn't recommend this, however, as you would never know if one of your VIs had this setting enabled...you would only find out once somebody else tried to use your VI on another LabVIEW install.
-D
