How to check the content in a text file line
hi all,
i had the following problem:
  • There is a text file with multiple lines of data in it
  • The data comprises of characters, numbers and symbols
  • In this file, any line can be commented (till the end) by using symbol ';'(semi-colon)
  • Now i have to find the number of occurences of a symbol '$' in this data, such that
  • it should not exist in a commented line
  • One more limitation is that ';' (semi-colon) could occur at any position in a line, i.e., if this occured in the middle of the line, then all the following data in the line is taken to be as commented one and we have to skip it and move to next line.
Plz do help.
santosh
santosh
Message 1 of 12
(4,242 Views)
Santosh
Can you post an example of the text file?
thanks
David
Message 2 of 12
(4,236 Views)
Hi santosh,
just a guess this is what you need.
Greets, Dave
Message Edited by daveTW on 09-15-2006 09:59 AM
Greets, Dave
Message 3 of 12
(4,232 Views)
hi david,
i think the following attachemnt will be sufficient:
i have to calculate the number of '$' in the file, excluding those which are preceded by ';' in the same line
santosh
Message 4 of 12
(4,223 Views)
Thanks Santosh
You should try coding up Dave's suggested solution and let Dave know that it works for you and provide him with lots of stars Smiley Wink
cheers
David
Message 5 of 12
(4,218 Views)
hi dave,
Thanks for ur reply,
the code which u gave works perfectly at all the conditions given in the problem,
except that when this semi-colon ';' comes in the middle of the line,
then we have to skip the data following it (semi-colon) in the line and count the number of occurences of '$' precedding ';' ,
i think here we face a problem.
Plz do reply.
santosh.
santosh
Message 6 of 12
(4,216 Views)
Try this ...
David
Message Edited by David Crawford on 09-15-2006 10:24 AM
Message 7 of 12
(4,204 Views)
Yes, I found a (for me) very common mistake, there must the "<>0" be replaced by a ">=0", then it works. David Cramers solution is very good, when you expect only one $ in a line.
Greets, the other Dave
Message Edited by daveTW on 09-15-2006 11:56 AM
Greets, Dave
Message 8 of 12
(4,193 Views)
hi dave,
could u provide the sample example that is compatible with version 7.0,
i could not able to open the code which u sent earlier.
santosh
santosh
Message 9 of 12
(4,182 Views)
Sorry,
I have only 8.0 on this computer, so I can only make 7.1- VIs. Perhaps it helps...
Greets, dave
Greets, Dave
Message 10 of 12
(4,177 Views)
