How to change the "Context Help" Title ?
I have build an exe.
I want to change the "Context Help" window title.
Is there a way ?
(3,112 Views)
Accepted by topic author Pnt
Well, that's a question I've never heard before. Is it possible? Yes. Is it possible using LabVIEW property/invoke nodes? I doubt it. If you're on Windows you can use the Windows API to use the SetWindowText function. You can use the lvwutil32 library to do this.
Note that you will need to do this every time the window gets displayed.
Message Edited by smercurio_fc on 11-26-2008 09:09 AM
(3,103 Views)
