How to change the numbers of items in a ring control in run time ?
Hi !
I would like change the numbers of items in a ring control in run time, but I can´t.
Thanks.
(2,733 Views)
Hello blaze,
did you try the "Strings And Values []" property of the ring?
LabView7.1 help says:
Array of clusters containing the strings from which you can select in the ring control
and the numeric values for each item. Use the Strings [] property if you do not need to
assign specific numeric values to each item.
(2,730 Views)
Thank you very much !
I had tried with Strings [] property and I could change the name of the items but not add more items, but with String and Values [] is possible ! 😄
(2,725 Views)
