How to change the front panel height and width runtime
How to change the front panel height and widht at runtime. Basically i want to decide height or width based certain parameters which i will in the run time.
Message 1 of 8
(6,105 Views)
Look at the Front Panel: Panel Bounds property node.  See the Context Help for description of the elements.
Lynn
Message 2 of 8
(6,099 Views)
Accepted by topic author Aspiration
ed. johnsold was first:)
Message 3 of 8
(6,098 Views)
Message 4 of 8
(6,090 Views)
Nice!!
But - dumb question - how do I place a property node linked to the front panel?
Dave
Message 5 of 8
(6,068 Views)
Dave,
Not a dumb question.  It is not obvious to someone who has not used property nodes much.
Drop a property node in the diagram. If the top part does not say "VI" then pop up on it and Select Class... Navigate through the menus to VI. Then pop up on the lower part and Select Property... And navigate to the desired property.
While you are in the menus look around a bit to get an idea of some of the other available properties you might need for your next project.
Lynn
Message 6 of 8
(6,057 Views)
Thanks!
It was navigating the upper part to VI that had me stumped.  Never dug through "VI Server"...
Dave
Message 7 of 8
(6,055 Views)
Yes PiDi, johnsold was first. But i marked your post as solution because somebody might have questions like how to do with Fp.WinBounds.
Smiley Wink
Message 8 of 8
(6,022 Views)
