How to change the font from "application" to a fixed font for a whole frontpanel
Hello together,
normally all my frontpanels use the apllication font. Now, we have mixed operating systems. Some are still using windows xp, the other windows 7. In windows 7 the standard application font changed. Running my programs under windows 7 results in ugly frontpanels, depending on the new standard application font.
Is there an easy way to fix the font for a whole frontpanel. I do not want to mark each text and change the font type.
Thanks a lot an best regards,
Michael
(3,097 Views)
Accepted by topic author MichaGue_01
Press Ctrl + A (Select All) and change the font. All the fonts will get changed to the selected style.
(3,096 Views)
Another possible solution is to config the ini-file for LabVIEW (labview.ini) or an application (ApplicationName.ini).
You can just insert the following comand
appFont="Arial" 14         (Set Application Font to Arial 14 point)
All possible comands are listed on this web page
LabVIEW configuration file/Fonts - LabVIEW Wiki
http://labviewwiki.org/LabVIEW_configuration_file/Fonts
(3,070 Views)
