How to change the Window Title on a per build spec basis?
I would like to be able to make 4 "build specificiations" against the same Startup-VI and be able to have the Window Title different in each of the output executables.   I know how to change the Window Title for the VI itself, but for some reason, I don't see the ability to override this information in Source File Settings --> Customize VI Properties dialog of the build specification.    Is there perhaps a way to do this programattically with VI server?  Perhaps there is a way I can define a unique symbol on each of the build specs and then do a case statement in code to determine which title to display based on the symbol that was defined?
(2,249 Views)
You can use the appropriately named Window Title property. In your project you can define conditional disable symbols (right-click on the project node and select Properties) and then use a conditional disable structure in your code. However, these symbols apply to the entire project, not to a specific executable. Thus, a better route would be to use the executable name (also accessible via a property), if possible, or some other distinction between the executables. What makes the executables different?
(2,227 Views)
